Pinion Drive Shaft Seal
Re: Pinion Drive Shaft Seal
The sleeve numbers are listed also...
1954 M37 WO/W
1969 M101A1
1969 M101A1
Thank you.
I had to look a 3rd time. You're correct there are some listed but nothing for the 1.875 I.D. x 4.014 O.D. x 1.000 sized pinion flange seal.
Update: (confirmed)
F&R Axle Pinion Flange Speedi-Sleeve #99187
(1.872in Shaft Diameter)
This Mother is just wearing me out. Any hints / tricks on getting the old one out??
I'm almost thinking this is going come out in small pieces!
BTW: The old seal was leather and the flange is worn/pitted. Definitely needs a sleeve.
Thank you.Cal_Gary wrote: ↑Sat Jan 18, 2025 12:16 am Here's how I get 'em out:
viewtopic.php?f=3&t=4305&hilit=penion&start=30
You bet-good luck!
This thing just kicked my ads. Paid "The Man" down the street. 15min to pop it out, another 15min to put in. It helps to have the right tools and a lift (for leverage).
Well worth the shop time $.
The first replacements are the toughest-once you go to school on them they become easier the next time around.
Hopefully I won't need to replace again. The flange was really pitted bad. A Speedy Sleeve fixed that!
I'm waiting till the rear axle seal bugs me then I'll work on that one. Maybe over the winter when I'm bored.
Smart to go with speedy sleeves!
