ran truck for 2.5 hrs today
ran good no issues
did good in what snow we had left
plan to get plates and insurance on it in the next week or so
and my brakes are very good
Thanks,TRAVIS
1952 M37 FARM TRUCK
Oh how awful! After all that readiness for operating your truck, something has gone terribly wrong! I am about to begin to put my motor back together, and if you can tell us what happened, perhaps I can avoid the same disaster.
we are thinking that some idiot that had it apart before me never marked the main caps then when he put it back together they were switched around
I put them back where the were when I pulled the engine apart
it may be salvageable but if I have to pull that darned thing again it sure ain't going back in
I will be selling all of my flathead stuff I have acquired
shoot me a pm if you need anything
there were no rods sticking out the side of the block
I'm slightly disappointed that it didn't explode
Thanks,TRAVIS
1952 M37 FARM TRUCK
I feel for you, all that work, to find your motor failing due to mis-marked caps. My machine shop has kept every thing marked, lifters, rods, caps, so at least I shouldn't have to worry about the kind of problem that destroyed your motor. Hope you get something going soon.
Would a good line hone (or line bore and hone) correct that problem? Is the crank damaged beyond repair?
New Aftermarket or NOS pistons and rings are not too expensive, and .20 over liners, the two I just bought were made by Cadillac in '71, are only 15 bucks. But your only real choice is to take it to a good machine shop, one that does more than just modern motors, and see what they have to say. Pretty much ever part for these motors is available, other than the blocks themselves. But I check Ebay sometimes, there may be one there. Old blocks are are out there, VPW has whole motors which they say at least are not frozen. I am certainly no expert on these motors.
I was offered a 440 with a 4 speed will it fit under the hood
and I was offered a 1st gen cummins running gear and the motor is making big power ,I am considering a body swap then I will have a streetable truck that will cruise at freeway speeds
decisions decisions
Thanks,TRAVIS
1952 M37 FARM TRUCK
I am dragging out the extra motor and am goonna see if I can get the old girl whipped into shape by the 12th of august so I can road trip it 100ish miles to the central Wisconsin military show
Thanks,TRAVIS
1952 M37 FARM TRUCK
