Plastic Fuel Tank?
Plastic Fuel Tank?
Does anyone know if anyone makes a plastic replacement tank? Are the tanks in a civilian power wagon compatibale with the M37?
No & No.
Ok then....:(
Lifer
Post by Lifer »
Anybody have a vacuum molding setup? Looks like an opportunity here for a little niche market in plastic M37 fuel tanks. :)
monkeymissile
Post by monkeymissile »
Lifer wrote:Anybody have a vacuum molding setup? Looks like an opportunity here for a little niche market in plastic M37 fuel tanks. :)
I am pretty sure plastic tanks are rotationally molded (big bucks for tooling). With vacuum forming you could only do half the tank at a a time and then would need to seal/weld them together to form a complete tank. I bet an aluminum fuel cell would be cheaper in the end. That's what I plan to do when my tank eventually dies.
1953 Dodge M43
Fail often to succeed sooner
We've custom built several out of steel, not exact replicas of course, but practical & have worked very well. As mentioned, tooling for various projects is very expensive & not at all practical to do unless you have a sure market for high enough sales to come out in the end. That is highly unlikely. Personally I wouldn't want a plastic tank because of damage vulnerability, but that's only my opinion.
NCmountainman
Post by NCmountainman »
I have heard that the plastic gas tank in the older Chev S10 pick up (and probably the GMC) is very close to the correct size. Probably would have to adapt the filler neck and the fuel outlet. Might be worth a check!
Also, the gas tank from the generator trailers (I don't know what the model designation is) are basically the same as the M37 but will need to have one hole covered. I have one of these for a spare, but not interested in selling it right now.
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
1942 Chev G506 (SOLD)
Nothing is Fool Proof to a suffeciently talented fool.
pfrederi
Post by pfrederi »
NCmountainman wrote:I have heard that the plastic gas tank in the older Chev S10 pick up (and probably the GMC) is very close to the correct size.
I have an Sonoma (GMC version of S-10) pick up and that tank will not work. I believe the tank you are thinking of came from Blazers and Jimmys
Paul f
mattveeder
Post by mattveeder »
S-10 pickup tanks will not work. I know these well, but maby a s-10 blazer up to 1993 could be made to fit if you really wanted. But if you are willing to spend some money you can get a marine tank made to your specs. I know a few people who have done this for street rods with the best success.
peter e mark
Post by peter e mark »
Success is a slipery word, as in offroading with a plastic tank that gets a pucture or ruptures ! Can you spell skid plates ?
1952 M37 W/W
mattveeder
Thats very true plastic can rupture. But that metal tanks could use skid plates if you are wheeling one of these trucks for sure. One good hit and it is over with. As far as that blazer tank is metal but it would nott make much sense to modify it to fit.
