brake line kits
Josh
brake line kits
Post by Josh »
are the repo brake line kits sold by MWM and adirondack dodge parts the complete kits, I.E. do they have all the lines from the MC all the way back to the rubber drop lines to the axles?
rixm37
Post by rixm37 »
Hi Josh
I bought the line set from VPW and I got all the metal lines including the line from the M/C to the frame fitting. You do have to reuse or buy new couplings to join the hard lines to each other. The overall fit was pretty good had to do a little tweeking only. The flexible lines came from AB Linn on ebay. I got new front flex lines when I did the front disk brakes.
Josh
Post by Josh »
are these the correct armored lines? I could make my own, but, I want the armored type.
rixm37
Post by rixm37 »
HI Josh
yes they are armor type.
I posted pictures of mine in the Techinical forum under "My Disk Brake Conversion" You can see pics of before and after the new lines went in. I have more if you want too see them. The post is now near the bottom of the page.
