M37 in Fort Collins Colorado
Any M37 owners in the Fort Collins colorado area? I'd like to compare performance with another stock powered truck.
- sbaumgartner
- PVT
Hi drowe ...
I *used* to live in Fort Collins/Loveland a couple of decades ago. Does that count?
I live in the mountains west of Denver now and have a stock truck running at 8500' elevation -- pretty sluggish but we get around.
PM if you want to compare notes. Don't know if I dare drive mine up I-25 to visit, but maybe meet somewhere in-between ...
There's also a MV dealer in Fort Collins who I think has a few M37s ... John Ferrie. Never dealt with him, so don't know if he'd be available to help, but couldn't hurt to try.
Steve
Steve
- uglyranger
- PFC
- sbaumgartner
- PVT
M-37 in Fort Collins
My truck has a recently rebuilt enginge. I live at about 7000 feet. It is pretty sluggish. Can get it up to almost 50 mph going down a steep hill. 45 mph is absolute tops on the level. Any uphill and it starts to slow down. On steeper hills I end up down in first gear. That seems a bit sluggish even for the old 230. Acceleration is always very slow. Can anyone describe how their truck performs? I checked the fuel supply and it is OK. the carb was rebuilt about three years ago (same time as the engine) but it looks like it is running rich to me (black deposits on tailpipe). I haven't been able to determine if the timing is right or not but it starts easy.
- sbaumgartner
- PVT
drowe:
Your performance sounds similar to mine at 8500'. I don't have a rebuilt engine, but my compression numbers are still good. I have to get down into 1st to climb steep hills too and 45mph max on the flats sounds about right. Although, I don't think a stock truck gets up much past 45mph with the 5.83 rear end even at sea level.
I did spend some time getting the timing right, running up and down the hills to get the best performance. I know Charles recommends setting the timing to 4 degrees BTDC, but I advanced mine even further to find the sweet spot for my altitude.
I just enjoy my truck for what it is and use my big Ford for any real work.
Steve
Steve
m37 performance
Generally speed isn't an issue for me. I use the truck around the property. Mine is set up as a brush fire truck in the summer and a plow truck in the winter. This summer I have been using it to water trees 20 miles away for an eagle scout project. Hauling 200 gallons of water I expect to be crawling uphill but I had hoped for a little better with the tank empty.
- sbaumgartner
- PVT
I was curious about performance too. My truck is at about 4,000' and does fine on level ground, but definitely has trouble on hills. I've only had my truck for a short time and am about to do my first tune up. I was wondering about leaning the mixture, but I'm not sure how to do it, or if it is a good idea.
Greg Loskorn
