New Noise
Re: New Noise
How about the clutch area? Try depressing the clutch pedal slightly while running to see if that makes a difference.
John Hedges
MVPA 17461
MVPA 17461
Re: New Noise
There was a lot of competing or background noise in the video. Is it possible to separate out or filter the sound?
Could be a worn camshaft, oil pump issue, valve lifter, distributor, generator or water pump bearing, etc, but go simple first.
What about the belts? Are they in good shape?
John Hedges
MVPA 17461
MVPA 17461
Re: New Noise
Pull the belt and see if it goes away. Quick and eliminates a bunch of items.
Re: New Noise
Excellent suggestion!
To me it almost sounds like high pressure air leak. Time for a quick compression test
1952 M37 - Mods = Locking hubs, battery switch, 2 bank charger, PB, PS, Pertronix SSI, Elect fuel pump w/filter&pressure switch, bikini top, tool box liners, 24v & 12v fused circuits.
Planned: Seatbelts
Planned: Seatbelts
Re: New Noise
Perhaps a manifold leak?
Re: New Noise
Go get one of those cheap auto stethoscopes and simply touch each component. When you hit the right one you will know it!
Re: New Noise
Excellent suggestion, Murf.
Now, I'm off to play doctor with my truck.
John Hedges
MVPA 17461
MVPA 17461
Re: New Noise
Same noise with the belt off, and after torquing the manifold (several nuts were loose).
M37
YEAR: 1954
YEAR: 1954
Re: New Noise
Any luck finding the issue?
Planned: Seatbelts
Planned: Seatbelts
Re: New Noise
Yep on the stethoscope.
Many years ago at the Yuma Proving Ground DRMO, a very pretty M37 was sold with a description "engine rod knock".
A friend bought it, and it turned out the generator bracket was cracked, causing what really did sound like a rod ready to come out.
Re: New Noise
I changed the break in oil (30w) to T4 15w-40 and the noise is gone. It’s been in there 2+ years but very low miles.
M37
YEAR: 1954
YEAR: 1954
Re: New Noise
Wow-I know some differentials require an additive but wouldn't think changing the engine oil alone would solve the issue.
Thanks for letting us know!
Re: New Noise
Poor man's stethoscope: get a piece of old broom handle or a similar size metal bar. Put one end on the engine part in question, and the other end against your ear. Works well to isolate sounds from different parts of the engine.
