Fuel Pump Connection
LegionPiper
Post by LegionPiper »
Hi there folks,
**** Updating the information. While the OD was 5/8" the actual NPT sizing is 3/8 inch, not 5/8 ****
This makes finding the part much easier, ( I really need to learn NPT sizing specs )
My existing fuel pump has a male 3/8-18 NPT 90 elbow to a female 5/16-20 inverted flare end.
It's been bent at one point so I'd like to replace it, however. this is a hard little part to find ?
Does anyone know of a vendor that sells these ??
Re: Fuel Pump Connection
Try McMaster-Carr or Midwest Military or your local Parker store if you have one.
You sure that isn't a taper pipe to invert flare fitting?
