Looking for one brass PCV fitting for the fresh air tube that goes from the carb inlet elbow to the oil fill tube. They are also used on the PCV lines that go from the rear of the block to the intake. I'm one short!
It's a 7/16" inverted flare to 1/4 MPT 90 deg.
WTB: PCV Fitting, 7/16 Inverted Flare to 1/4 MPT 90 deg
Re: WTB: PCV Fitting, 7/16 Inverted Flare to 1/4 MPT 90 deg
That is a Dorman item and obtainable from a REAL auto parts store.
just me,
If you can find a P/N I'm all ears! I've had no luck.
I used the NSN and could not find one. I checked all my suppliers. Weatherhead, Plews, Parker, etc. Everyone skips 7/16 tube. Unless you can find them used, I'd change tube size or make my own fitting.
I think I may have located a used one
As you found that fitting is no longer made.
Hope your used on works out.
The only other thing to do other than used is to change to
3/8 pipe and fittings.
Tom
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Midwest Military has these.
John
John
