Engine gurus:
I was hoping someone could help clarify a discrepancy in the maintenance manual. Figures 70 and 102 have opposite arrows pointing to the idle speed and mixture screws. Which one is which?
Thanks in advance,
Idle Speed vs. Mixture Screws
Re: Idle Speed vs. Mixture Screws
Mixture is in the base of the carb and is a needle. Idle speed is external to the carb and pushes against the throttle lever.
