transfer case rubber mounts
Is there a better option for replacement mounts than the oem rubber ones? mine are like solid plastic now, and I was wondering if anyone had found some polyurthane replacements.
Re: transfer case rubber mounts
Hard to believe there are no options for these other than the 50 year old nos rubber ones.
isaac_alaska
Post by isaac_alaska »
If I had dimensions I could print a set out of a softer rubber.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Or machine them from polyurethane or whatever material you wanted.
