hello of France
Re: hello of France
Parley vou via Google Translate-copy the French and paste it in:
https://translate.google.com/
yoann44
Re: hello of France
Post by yoann44 »
Hello,
a lot of work on the M37. I have a problem with the carburetor. Should I put the pipes but I have not the carburetor diagram. I lost my photos. Someone there any carburetor pipes to engine Photos
thank you very much
merci beaucoup 8)
Re: hello of France
From TM 9-2320-212-20 Organization Maintenance Manual for Truck, Cargo: 3/4 Ton 4x4 M37 and M37B1
From TM 9-1840A Ordnance Maintenance Engine (Dodge Model T-245) and Clutch (Borg & Beck Model 11828)
yoann44
Re: hello of France
Post by yoann44 »
hi,
I have a problem with the engines. I need some important information.
I hope my translation is good.
A big thank you for your help
French yoann of Normandy
engine : 230 ???
crankshaft tightening pattern
Con Rod Assy tightening pattern
size standard piston
size bore piston
size standad crankshaft
:size bore Crankshaft
Re: hello of France
yoann44 wrote:hi,
engine : 230 ???
size bore piston
Ces informations devraient tous être ici: http://www.imfmotorpool.com/files/TM9-1 ... clutch.pdf
Les écrous de bielle et les principaux boulons de chapeau de palier ne disposent pas d'une séquence de serrage spécifique. (The connecting rod nuts and the main bearing cap bolts do not have a specific tightening sequence.)
yoann44
Re: hello of France
Post by yoann44 »
Thank you very much has you I am going to be able to look at the book. Have to try to translate now.
Thank you thank you
Re: hello of France
Glad to help.
Cylinder bore standard size = 3.250 inches
Crankshaft main bearing journals standard = 2.500 inches
yoann44
Re: hello of France
Post by yoann44 »
Thank you for your help :D
yoann44
Re: hello of France
Post by yoann44 »
hello,
I looking for a crankshaft and Crankshaft Bearing for engine t245 to send in france.
Store usa?
Thank you for your help :)
