new regulator from vintage power wagon???? somethings wrong
- PFC
plugs in good mounts good... when i try to put on my battery cable on it makes the generator hum and it may be turning ( not sure).. i just dab the cable on i don't leave it on there cause it sparks bad.... any advise.. anybody have this issue before. 195 for this solid state regulator
Re: new regulator from vintage power wagon???? somethings w
there was another thread on here not long ago where someone was discussing a generator acting as a motor. let me see if i can find it for you
*edit* here it is
Genny wants to be a motor
*edit* here it is
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
let me see if I got this
how do you know the genny was not charging after the wash ? did you put a volt meter to the batters ? how many volts are there ? is the wire good? did you check the three leads for continuity ? is there any short to grounds ? is the generator full of water ?
what is the state of your wiring harness ?
it is easier for us to help if we know your truck. have you thought about making a build thread in the builders blog section? post some pick and history of your truck. have it all in one place.
and remember kids its so easy its hard
then you bought a new part and problems persist.junkyardog wrote:i washed the engine down 3 weeks ago and after that it did not charge...
- PFC
well i have another truck and took the regulator from that one and it charges...then i put the solid state one on and it does not charge...
dead in the box sucks. did you talk to the seller?
- PFC
yes he will do a return for me..
- Tim Powell
- MSGT
Hey Ya-All.
I've had good luck dealing with VPW in the past. Jen & Steve are good guys.
Hope you get your problem licked.
By the way, "Junkyard-Dog" has been my "C.B. Handle" for 45 years!
- PFC
i got called that from working in a truck junkyard for 12 years.. best job i ever had... took its toll on the body though.. you tend to feel what you did at 20 when you get 50
