HI-LIFT help
52PLOWERWAGON
HI-LIFT help
Post by 52PLOWERWAGON »
im looking to invest in a hi-lift jack, I only want to buy it once whats the best one to buy
and does snapon /bluepoint make one?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Re: HI-LIFT help
Post by isaac_alaska »
Hi-lift is the original I think. Or possibly handy-man. Whatever you get, LEARN TO USE IT. I move houses, and this is the most dangerous tool on the entire job.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Re: HI-LIFT help
I use my hi-lift as a pulling/pushing device. As a lifting tool, it is way too damned dangerous. The best use I've found for it is pulling fence posts.
ZGjethro
Re: HI-LIFT help
Post by ZGjethro »
Thirty years ago, I was working on a concrete foundation crew on summer break from high school. My boss was using a handyman jack to lift the tongue of a trailer full of forms, and the handle got away from him. The handle started flailing around an hit him in the mouth. It knocked all his upper front teeth out. I learned to give the jack a lot of respect after that
Jess
Re: HI-LIFT help
Post by Jess »
The real deal, Hi-Lift is/was produced in Denmark at one time and is pretty reliable as is Jack All. Both are marketed by US businesses and have parts available. I can't say as much for the other 'farm jacks' from you-know-where. Already mentioned, is the very real danger of this jack from the handle flailing. Proper setup is critical to prevent it from failing under load. I have a shackle and a couple of chains to use for pulling, another use for these jacks, in lieu of a winch. Be very cautious while you are getting used to what it can and will do.
Re: HI-LIFT help
I got mine from NAPA-no issues, but as others have mentioned, RESPECT this type of tool in particular or it can kill you.
My handiest task for mine was when replacing my rear springs-I used the Hi-lift and some jack stands to get the weight off the old springs; once replaced, I lined up the spring front anchor and pin and installed it then used a ratchet strap on the other spring end, attaching it down low to the high lift jack to ratchet the other end of the spring and shackle down into place. Worked perfectly with no muscle pain :)
ZGjethro
Re: HI-LIFT help
Post by ZGjethro »
High Lift has a newer jack out. It is quite a bit more than a standard jack, but it is set up for more than lifting only. http://www.amazon.com/Hi-Lift-FR-605-Re ... B006BQL4CK
52PLOWERWAGON
Re: HI-LIFT help
ZGjethro wrote:High Lift has a newer jack out. It is quite a bit more than a standard jack, but it is set up for more than lifting only. http://www.amazon.com/Hi-Lift-FR-605-Re ... B006BQL4CK
wow that's a nice jack :D and an even nicer price :shock:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: HI-LIFT help
A 48" Hi-lift under a bumper won't even get a tire off the ground due to the way the springs work.
They are nice for unhooking heavy trailers, tho.
Dennis
isaac_alaska
Re: HI-LIFT help
PoW wrote:A 48" Hi-lift under a bumper won't even get a tire off the ground due to the way the springs work.
Dennis
it will, but if you have the winch bumper installed, and you arent' centered on the end of the frame rail, it can twist the bumper. if you have a long cab it can also twist the cab quite a ways. grandpa had a special adapter made up to lift on the hub, which worked very well
Isaac
Fairbanks, AK
Photo Gallery
Re: HI-LIFT help
Why not find an original G741 bottle jack?
It fits into the specially-designed axle spring plates.
The truck was really well thought out in spite of most civvy owners.
You probably always wondered what the 'forks' sticking out were for...
Re: HI-LIFT help
I made an adapter for my bottle jack to fit in those forks.
isaac_alaska
Re: HI-LIFT help
Sometimes the axles are sitting on the ground and a bottle jack won't fit. Would like to see a photo though! Sounds cool. I didn't know there was a jack.
But to answer the original question, maasdam.com makes one that looks very nice
Isaac
Fairbanks, AK
Photo Gallery
Re: HI-LIFT help
I have a Hi-lift X-treme jack (48"), and it's been an invaluable tool for a variety of jobs. One nice feature is that it can apply force in either direction.
I've even used it to jack a couple of old garages back into plumb while reconstructing the foundations.
It will also fit in the tool box under the M37 bed, but you won't have a lot of room left for anything else. :lol:
As others have said, it's a useful tool, but it can be unforgiving if used improperly.
52PLOWERWAGON
Re: HI-LIFT help
i was gonna mount it on my hard top
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
