900 x 16 was the original tire size on the m37. What is the modern equivalent metric to this?
Example xxx/xx/16
900 x 16 what is the modern size
Re: 900 x 16 what is the modern size
9x16 is a 100% aspect ratio tire on a 16" rim, so 9" wide, and 9+ 16 + 9 (or 34) inches tall. gives a standard tire size of 34 x 9 x 16
to find the metric size, just multiply the tire width by 25.4 to get the metric equivalent, in this case 9x25.4 = 228.6
then you need the aspect ratio and rim size.
so by the numbers, the modern exact equivalent size would be 228.6/100R16.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
255/100R16 is the metric radial equivalent.
