stubborn brake drum screws stubborn no more
52PLOWERWAGON
Post by 52PLOWERWAGON »
I figured out a trick to day on how to get out them tough brake drum screws
1.spray w/ penetrating oil
2.beat w/ 2 lb hammer
3.heat w/propane torch
4.beat again w/ 2lb hammer
5.thread a 3/8 in bolt in hole used to press drum off
6.tighten snug then turn bolt 4-6 rotations
7.back off bolt
8.use a big flathead screwdriver w/ visegrips attached for leverage
and they should come right out
if not try again starting with step 1
and brush lots of antiseize on the screws so you don't need to struggle next time
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Re: stubborn brake drum screws stubborn no more
Post by isaac_alaska »
yep i will be trying this this summer :D
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
w30bob
Post by w30bob »
Travis,
By the time you're done with your M37 you are going to be an expert at steps 1-4......it's just that kind of vehicle. :mrgreen:
52PLOWERWAGON
I'm seeing that already bob :mrgreen:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
