bed reflectors
Gerry
bed reflectors
Post by Gerry »
Is there a modern part # I can use to order the body reflectors? Hope to buy local and save some $ Is there a special one that is original to the truck that I should try to find to be correct<
Gerry
53 M37
Re: bed reflectors
The ones on the truck are cat eye reflectors. NAPA sells a modern equivalent but the reflector pattern is different. The cay eye has a diamond pattern with concentric circles when viewed At different angles. The new ones don't have the concentric circles. Only matters to the rivet counters. Also, my originals are 2 piece. The replacements are one piece. When installed look identical.
chris olson
Re: bed reflectors
Post by chris olson »
Grote 40233 Amber
40232 red
1952 M37cdn
Gerry
Re: bed reflectors
Post by Gerry »
Thanks Chris
Gerry
53 M37
