Mounting Radios
Mounting Radios
Hi Guys,
After looking forever I finally found a reasonably priced MT299 mounting base for my radios to mount on the troop seat. The price of those things is nuts....but I found a complete one in Italy for $50. It's gonna cost $70 to ship it to me, but that's still way less than what folks on this side of the pond are trying to get for them. So now I need to find the mounting instructions. Does anyone now the tech pub number that describes how to mount radios in the M37?
thanks,
thanks,
Re: Mounting Radios
It's not a TM, it is actually a bunch of drawings (old blueprints). I have a pretty complete set (maybe a complete set) of all the radio installations for the cargo bed.
You need to remember that these radio installations were usually modified to the mission or needs / desires of the the people using them and operating them so there is really no "standard" installation. These drawing give you a "suggested starting point" as it were.
Let me know what you are trying to use your radios for, and which radio system you are trying to use and I'll see what drawings I have that will illustrate your installation.
Re: Mounting Radios
Hi 52,
I knew you'd reply.
I've got an RT68 and a PP112 and the MT299......so the simplest install for me would be a VRC-10. I'm not looking for anything elaborate, my truck has the holes in the bed wall for the antenna mount so I figure I might as well install the antenna and put a radio in it. I haven't even begun restoring the truck yet, but if I know what pieces I need to look for I can pick them up when I see them at the meets.
thanks,
I knew you'd reply.
thanks,
Re: Mounting Radios
I'll dig out the drawings and send you a copy of the components parts list (control box, speaker, handset, antenna, etc.) and TM's this weekend. Also, if you don't want to drill holes in your cargo bed seat, I can send you some pictures of a mounting board I made out of 3/4 inch plywood (it's exterior plywood, maybe marine grade - I'll check) that lets you install and remove the system with a lot less disassembly and no holes in your seats.
52 M-42
52 M-42
Re: Mounting Radios
52,
Thanks, that will be great. I'm definitely interested in seeing the plywood mount you describe. I'd really don't want to drill holes in the seat bottoms.
thanks,
thanks,
Re: Mounting Radios
Not only that, but lots of installations used a "T" shaped piece of welded angle iron from the middle of the inner fender vertical up under the seat boards. Bolted together tight, no bouncing allowed.
DDG aka PoW
DDG aka PoW
Re: Mounting Radios
I've got a couple of those T braces to use when I mount my A/N GRC-7 system. It is a big, heavy system (about 240 lbs.). I'm planning to make a u-bolt to clamp them together (the seat and brace) so I don't have to drill holes in the seat.
Re: Mounting Radios
It would be interesting to see some photos of the supports for the seat. I also have a RT68 with the PS and mount which I want to put in the back of the truck. It has to be fairly easy to remove though so I can swap out my comm box into the bed.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
S-89 Comm box
Re: Mounting Radios
I'll try to take some photos this weekend. There is just not much to them. I those will be one of the last things I install because they require holes to be drilled in the bed of the truck, and doing that (even when it is "standard practice" or "part of the installation process") make me wince. I just don't like drilling new holes; even though when I was in the military we would blast holes in these trucks without a second thought or any hesitation. Must be one of the differences between 17 - 18 years old and 63 years old and between "government stuff" and "my stuff".
Re: Mounting Radios
Hi Guys,
Good subject. I have a radio mounted in the back of my truck, but I need to get smarter about it. It is all mounted, I have the power cable, antenna, larger generator, and grill mounted electrical cooling component wired in to the main harness. I do not know what was used as a microphone and any other thing I need to get it to be a complete functional set. How is the best way to grow this knowledge?
I know my first step is to get my radio identified. I'll try to get some pictures of it this weekend. I am trying to learn how to get pictures posted as well.
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Re: Mounting Radios
Once you get your radio identified, it should be pretty easy to find the all the missing pieces (maybe not cheap; but pretty easy to identify them).
RMS posted a thread awhile back on how to post pictures. You should be able to find it with a search; if not, one of the moderators can direct you to it.
52 M-42
52 M-42
Re: Mounting Radios
BTW, I DO have the fabrication drawing for the "T" bracket seat support for the radios, if anyone is interested. I found it earlier this week when I was going through all the radio documentation.
Let me know.
52 M-42
Let me know.
52 M-42
Re: Mounting Radios
I have not been able to get my pictures added to my posts yet, but I did get some of them loaded to the Photo Gallery. Please look at my pictures and see if they are of any help. They are in Dana S. Cook Gallery. Looks like I have an RT-68/GRC, and an R-110/GRC. Where is the best place to become educated on my radio?
MVPA Member #23780
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
Re: Mounting Radios
Hi D,
This site shows you all the components for the radio sets. If your asking about how to use your radio.........I don't know. Probably search for the military manual.
http://www.nf6x.net/1999/01/1950s-vehicular-radio-sets/
