Jeep 4.0 repower?
QRS89
Jeep 4.0 repower?
Post by QRS89 »
Hey,
New to the forum. I just recently bought my first m37. I looked for a few years before I found on in my area. It sat for 10 years but busted right off with fresh batteries and some fuel in the carb. The transmission is stuck in 2nd gear. The shifter is just moving freely. I need to pull the top cover off to inspect.
Back to my original question - has anyone done a jeep 4 liter conversion on one of these? Would it be easiest to leave transmission and transfer case or replace with engine swap? I've got a fresh 4.0 sitting in the shop an wondering if it's worth the trouble. Any advice would be greatly appreciated.
Quade
W_A_Watson_II
Re: Jeep 4.0 repower?
Post by W_A_Watson_II »
A couple of us have thought about it and was looking forward to someone doing it. I know the 4.0 I rebuilt (bored and stroked to 4.6L) in my 93 YJ has more power than the basically stock 318 (323 cu in.) in my M37.
If I was to do it' I'd use the Jeep's transmission, either manual or automatic of your choice. And then you have to consider the transfercaae choice. If the transmission is a manual and out of a 2WD Jeep you can keep the M's divorced NP200 TC, other wise I'd go with an aftermarket passenger side drop TC that will mate to your transmission. The real issue here is the the resulting rear drive shaft issue.
With a centered output TC and offset rear axle differential, the drive shaft angle will be unusual, and if it's an off road or low speed on-highway use vehicle, it should work well with proper pinion alignment and CJ drive shaft. If it's on on highway use vehicle, then you have a lot more to consider, like swapping axles as well.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
QRS89
Post by QRS89 »
I never thought about using a 2WD Trans with the divorced tc. I'll have to take some measurements! The 4.o I have is out of a 2WD jeep mj. This has the potential to be easier then I thought. Thanks for the input Will.
I've had 4 or 5 jeeps with the I6 and most of them had over 250k on the motor and Trans. They are good strong motors with good low end torque. Can't say as much for there new v6.
52PLOWERWAGON
Post by 52PLOWERWAGON »
I would slide the t case back and run duel t cases :twisted:
rickv100
Post by rickv100 »
I think the exhaust is on the wrong side in the 4.0
Rick
52PLOWERWAGON
rickv100 wrote:I think the exhaust is on the wrong side in the 4.0
Rick
it is
