20 inch tires,
howard
20 inch tires,
Post by howard »
is any one here looking to sell or made a set of 20's for a m37. i would like to try 900x20 . i heard model aa truck rims will fit also. also heard that the older 10 hole chevy rims can be drilled out to fit the 5 lug bolt pattern. any help would be nice..im not looking to go 60 down the road. i just like the look.
Re: 20 inch tires,
Both the 20" wheels you mentioned are too narrow for proper running of 9.00-20 tires. You would spend your time on the center rib only, with proper inflation.
Been there, tried that, had to widen a set of them to make it work.
Easier to use Goat wheels and 11.00-18 NDCC's. on adapter plates.
I've also seen 6-bolt deuce wheels with modified centers on an M37. Looked really good, he had cut the flat bolt holes part out of 16" wheels and welded it into the 20's
DG
