Vacuum brake booster?
Is there a booster that would work on a stock setup for some extra braking power without spending the cash on front discs?
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
S-89 Comm box
Sure, go to NAPA and look at the core illustration guide book. Pick one that you think will best fit your application in relation to plumbing & mounting.
I doubt that they're still available, but I had a '35 Ford school bus with vacuum-assisted mechanical brakes, even. The rod from the pedal went into the booster on one side and the primary linkage came out the other side. It worked well, actually, but brake adjustment was pretty much a daily thing!
Re: Vacuum brake booster?
[URL=http://news.webshots.com/photo/107 ... .jpg[/img]refit1701 wrote:Is there a booster that would work on a stock setup for some extra braking power without spending the cash on front discs?
Hey John,
Mine is a rebuild from GM, Caddy to be exact, unfortunately is ain't all its cracked up to be, (JMHO) I'm getting ready to install Ray's disks.[/url]
It was just a thought. I have been eyeing the disc conversion but with a final total probably in the $800 for the whole thing, I've had to hesitate. I do intend to drive my truck some, she won't just be for shows.
My truck is missing so many things at this point.
I guess I could get the hubs done and then just do the rest when I can afford it.
-John
S-89 Comm box
S-89 Comm box
You have to use a large enough booster to actually make a difference, we've done some on fire trucks that helped enough to slide the wheels loaded on a brake application. A unit from something like a Ford F600 truck is large enough to make it happen. You can buy these at NAPA all day long.
Oh boy, that would be hard to retrofit under there, considering where the MC is. I should just stop asking questions about things like this.
I might as well have asked if I can put an M1 tank turret on the hood.
-John
S-89 Comm box
S-89 Comm box
Under the drivers seat is a great location & makes for easy plumbing.refit1701 wrote:Oh boy, that would be hard to retrofit under there, considering where the MC is. I should just stop asking questions about things like this.
Hmm....ok. I'll look into it further.
As always, thanks for the advise and comments.
-John
S-89 Comm box
S-89 Comm box
Caddy Hydro-Vac Booster
Mine is behind the cab, to the left of the drive shaft, I'll try and take a better piccy of it. Right now it's welded to two cross-members.
A pic *would* help my imagination.
Not having used a booster before (Mustang didn't need one) I thought they had to be attached to the master cylinder.
-John
S-89 Comm box
S-89 Comm box
[/url]
[URL=http://news.webshots.com/photo/297 ... .jpg[/img][/url]
The last shot is from the rear, looking forward. The second one is looking back @ the unit, the first is from under. It's attached @ the back by a bracket , Bill Kirkpatrick made both of them & welded them to two different cross members, bummer!
