Ok I need some parts
Lifer
Post by Lifer »
"Oil bath" = air cleaner.
bubba_got_you
Post by bubba_got_you »
These are the must haves. the U joint looking thing for the steering rod that holds it to the dash (lol), distributor, and 24v generator.
May God grant me with the serenity to accept the things I cannot shoot, The ability to shoot the things I can and a place to hide the bodies
Lifer
Post by Lifer »
The "u-joint looking thing" that holds the steering column to the dash is a u- bolt. I don't know the specs on it (bolt diameter, length of legs, distance between legs, or thread pitch) but you may be able to come up with a suitable replacement at your local hardware of farm supply store.
knattrass
Post by knattrass »
Lifer - there is a little plastic bearing or liner that goes inside the bracket around the column that we could not find. Ours was only pieces. We ended up taking a section of a peice from a thick plastic tub and heat formed it into shape. This thermoplastic material provides a good low friction surface.
Lifer
Post by Lifer »
"Whatever works," right? :wink:
The air cleaner housing is actually an oil bath because the housing uses oil to filter the inbound air-there is no paper filter element.
