Manifold Heat Riser Stud
pwrwagonfire
Post by pwrwagonfire »
Does anybody has a Doorman # for the stud which holds the manifold heat riser in position?
Mine snapped off, and I was going to drill it out/tap it and replace the stud while the manifold is off of the truck.
Do you think there is danger of the drilling process cracking the manifold?
Thanks in advance!
-T
pwrwagonfire
Re: Manifold Heat Riser Stud
Answered my own question after a bunch of searching.
If anyone else is wondering,
The stud is is 1/4” x 1” with 28 tpi on one end and 20 tpi on the manifold end
-T
