Warn M13 hubs
Warn M13 hubs
Does anyone have a link or a place to obtain copies of the manuals for these hubs? I aquired a set and want to take them apart and clean them up, but I sure would like to have a "roadmap" to get them back together.
pwrwagonfire
Re: Warn M13 hubs
Post by pwrwagonfire »
I have a link on my other computer to a PDF of the manual...it has exactly what you are looking for.
I will see if I can find it.
EDIT: Here you go!
Re: Warn M13 hubs
Thank you very much!
pwrwagonfire
Re: Warn M13 hubs
06boblee wrote:Thank you very much!
Not a problem!
I got a set of M13's as well, we're two of the lucky ones!
Re: Warn M13 hubs
Now that my original quest is done, I may as well try for more- is there a rebuild kit still available for these? I guess it would be o-rings and gaskets. Will the standard M37 hub gaskets work?(there is one inside the hub that looks the same in the pics).
Again, Thanks!
pwrwagonfire
Re: Warn M13 hubs
06boblee wrote:Now that my original quest is done, I may as well try for more- is there a rebuild kit still available for these? I guess it would be o-rings and gaskets. Will the standard M37 hub gaskets work?(there is one inside the hub that looks the same in the pics).
Again, Thanks!
I used RTV silicone in place of paper gaskets on a couple different trucks...works great.
However, if you decide you want to go with the paper, it is FEL-PRO FPG 4390
I am not aware of a re-build kit, but if you find on let me know please!
-T
Re: Warn M13 hubs
I talked to Warn a couple of days ago asking about rebuild kits for the M13 hub. They no longer have ANYTHING for this hub, and according to the guy I talked to the o rings and other parts are a different size from any other warn hub (really?). I am mainly trying to replace the o rings on the dial, does anyone know if they are really an oddball size? If I can find them at Graingers or somewhere else I will post it here.
Monkey Man
Site Admin
Site Admin
Re: Warn M13 hubs
Post by Monkey Man »
When I replaced the ones in my hubs years ago I got them by taking the hub to a bearing supply place, they found generic ones that were a good, firm but not stretched fit and also supplied me a little thumbnail sized tube of lube for each one, I think the whole lot for both hubs was under $10 Aud...
MM :D
Trained Monkey on Guard
dodgem37@netspace.net.au
JimC
Re: Warn M13 hubs
Post by JimC »
M13's for me as well.
Brigand
Re: Warn M13 hubs
Post by Brigand »
If anyone has a single M13 they would part with, I am in need of one. At some point someone installed a Superwinch hub in place of the nearside Warn.
Please let me know if you can help. Thanks.
Brigand aka Bob Thompson
I would never join any club that would have me as a member.
