How do you change the windshild glass in the M37?
I have removed the 2 interframes from the main frame and removed the wiper motor and the 2 bolts and nuts in the unper couners. I can not get anything to move or wigle, do want to get riugh with it. There is not a lot of rust it just seams to be stuck any tricks ? thanks Phil
Phil in Mt
41 m2-4, 42 m6, 42 g-506, 42 mb, 43 mb, 44gpw, 50 m38, 50 m75, 51 m38, 51 m37 halfbreed ,55 m38a1, 60 m170
62 m100, 69 m416
62 m100, 69 m416
Re: How do you change the windshild glass in the M37?
You are on the right track, the top piece of the frame slides off at the corners, the glass is then free to slide up & out of the frame. Rust just has it stuck most likely. If you are changing the glass anyway, the easiest solution is to break it & then remove the pieces that are left along with the weatherseal. Thoroughly clean & paint the frame, install a new weatherseal & glass.philin mt wrote:I have removed the 2 interframes from the main frame and removed the wiper motor and the 2 bolts and nuts in the unper couners. I can not get anything to move or wigle, do want to get riugh with it. There is not a lot of rust it just seams to be stuck any tricks ? thanks Phil
