Rubber coated clips for wires on frame, where to buy?
Does anyone have a source for the clips bolted to the frame and firewall that can be bent around hoses and wires? I can find the ones that bolt on but are bolted shut when attached, im looking for the ones more like the originals?
Re: Rubber coated clips for wires on frame, where to buy?
If you have your old ones, you can do what I did. I peeled off the remainder of the old rubber, reformed them to a nice round shape over a rod clamped in a vise, sandblasted them and painted them black. Then dipped them several times in Plastidip. They came out just like new.
Keep in mind, not all of the clips were rubber coated.
Tim
Tim
does the plastidip hold up to bending? I was wondering if that would work. Some of mine are beyond saving also.
Thanks for the info
Thanks for the info
I dont know how the plastidip would work if you dipped a straight piece and then bent it into a loop, but I would think it would do fine. Mine were all bent into "J" shapes and when I formed it around the wiring etc. it stayed on just fine.
Tim
Tim
- m37jarhead
Like PW Tim, I sand blasted, primed and painted all my clips. Then dipped them in Performix brand
"Plasti Dip" that I found at Home Depot. I dipped the pieces more than once for added thickness.
Follow the directions on the can.... slow in, slow out. Tedious.
Once the can is open the dip wants to thicken but can be thinned again with xylene, toluene, etc.
As a further test, I dipped the handles of a pair of dikes and a pliers... several times.
At this point no telling how well the "dip" will perform. Back at ya' in a year or so.
JB
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
I will pre form them but its an ongoing project so they will see some use as I update line and stuff, this is good info, thanks.
Is there a source for them to replace the ones that are rotted out?
I started to do this and did a few just fine but my surplus friend ended up finding 4 boxes of NOS ones
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Reeeaaallllllyyyy
any chance he has more?
Thanks again for all the help guys. I will get pics someday soon, not that they are much to look at.
Look at Home Depot or at Lowes etc. in the electrical isles. They have the same type of clamp. Unless you're going for orginal and then that may not be an option.
nhjohnny1 wrote:Reeeaaallllllyyyyany chance he has more?
Nope
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
k8icu wrote:Look at Home Depot or at Lowes etc. in the electrical isles. They have the same type of clamp. Unless you're going for orginal and then that may not be an option.
Ive seen them and I think they are close enough. Id use them.
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Ill check it out, they just have to be open like the originals so i can add/remove stuff without unbolting the clip, are the depot ones one sided or two sided like the originals?
