speedo cable
SydneyM37
speedo cable
Post by SydneyM37 »
I have been trying for about an hour to fit the connector on the transfer case, i am finding it impossible to bend it about 90deg so as to screw it on.
anyone else have this kind of dilema, i'm feeling since i have 4.89 why bother, as it will be out anyway.
Bruce McCann
Keep em green to keep ya keen
CGarbee
Re: speedo cable
Post by CGarbee »
SydneyM37 wrote:I have been trying for about an hour to fit the connector on the transfer case, i am finding it impossible to bend it about 90deg so as to screw it on.
Bruce McCann
Since you have 4.89 gears, why not go to your local speedometer shop or streetrod parts supplier (or mailorder house) and get a right angle adapter that also corrects the gear ratio? That way, you not only "solve" the right angle bend problem (not only making it easier to attach the cable, but reducing the possibility that the cable will break at this location from being stressed...), but you get a speedo that reads correctly...
I find attaching a cable to the stock setup to be a pain, but doable...
I really like the DATCON electric speedo in my Cummins powered truck since it has a sender that bolts onto the t-case with a pair of electrical leads going to the speedometer head that eliminate this issue, but then, the truck is a ways from stock... :)
Good luck.
'53 USMC M37 w/Cummins 4BT
'64 XM708,
'51 M38
http://www.garbee.net/~cabell
SydneyM37
speedo
Post by SydneyM37 »
I'm nearly thinking of getting one of those NAV man gps things as they have the correct speed via the satelite.
Bruce
M-Thrax
Post by M-Thrax »
If you can't find one locally then try George ( click below) he carries them for the civie Power Wagon which has the same driveline as the M-37
http://homepage.mac.com/gwellman/
SydneyM37
adaptors
Post by SydneyM37 »
I just sent them of an email, just looking at the site though, i didn't see mentioned anywhere about 90 deg adaptors.
Anyway thanks for the link, and i shall await my reply.
Bruce
knattrass
Post by knattrass »
Bruce - I had left a message for George as well, site shows he is in MI, meaning in my state! If I hear, I will post.
Keith
gwalker
Post by gwalker »
68 M-715 MVPA# 2710
knattrass
Post by knattrass »
Thanks - just called.
A 1:1 ratio, ninety degree, 7/8 inch thread is $125 +s/h.
SydneyM37
adaptor
Post by SydneyM37 »
thanks for that guys
Bruce
