Leveling my M37
Gmyoung
Leveling my M37
Post by Gmyoung »
I'm new to the site and new to the M37's. I purchased a 1954 CDN just a few days ago and love the truck. It was mostly restored when I purchased it all except the tailgate and bed floor. I have 2 questions, 1) I was thinking of leveling the truck since it has a pretty decent rake. Is there enough travel in the front shocks to ad a ~2" block below the leaf springs or should a take a few leafs out of the back? 2) I'm in the process of removing the floor in the cargo box and was wondering where I could buy one similar to original. If not I will have to make one but it would be flat plate and not have the rib structure in it unfortunately.
MarkPick
Re: Leveling my M37
Post by MarkPick »
Welcome Gm. I cant speak as to removing leafs or any of that, there are guys on the site a whole lot more knowledgeable than I am who can chime in. But as for the new floor John @ Midwest Military has new floor panels for sale. Here is the link. http://www.midwestmilitary.net/m37p11.html
That link should take you right to the page (11) that they are on. Best of luck and hope that helps.
Mark
USAF Retired
Desert Storm
Iraqi Freedom
Tuko
Re: Leveling my M37
Post by Tuko »
adding blocks on a steer axle is a no-no. if you want to do it right a re-arc of your stock springs or an add a leaf or 2 from another set of stock springs are a better option.
51 Dodge M37 W/W 4BT/NV4500
My G741 Registry Entry
m15256
Re: Leveling my M37
Post by m15256 »
I don't know what you mean by "leveling". Perhaps you should look at the front springs closely to see if they are collapsed or broken. I definitely wouldn't take any leafs out.
RICK
M 152 CDN
M 56 (V41)
refit1701
Re: Leveling my M37
Post by refit1701 »
These are 1 ton trucks "on road" and so have a rake favoring a higher rear end to compensate for the weight when fully loaded.
Our trucks are mean looking all jacked up in back..... :)
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
Monkey Man
Site Admin
Site Admin
Re: Leveling my M37
Post by Monkey Man »
Hahaha...
When I first read the title I got the thought he meant "Level It", a couple of pounds of C4 should do it :wink:
My truck has a rake on it too but it levels out when loaded, yours should too.
MM :D
Trained Monkey on Guard
dodgem37@netspace.net.au
Gmyoung
Re: Leveling my M37
Post by Gmyoung »
Yeah I understand the load levelling. I own a dodge ram 3500 and it to is raked for that reason but I did not intend on loading my M37. I'll look into adding a leaf most likely thanks
Monkey Man
Site Admin
Site Admin
Re: Leveling my M37
Sounds good, show some pics when done please...
My truck has the heavy duty spring set in the back, shory of modding the whole spring sets I'll just go with what I have, if I put a water tank in the back along with all my other junk it should level out nicely...
MM :D
RMS
Re: Leveling my M37
Post by RMS »
just swapped out my front leafs and accidentally made the truck level.Image
the springs i swapped in came off a m43 with a 360 in it. the pack is 1.5in thicker than stock and has five extra leaves. one below the top two, one half way down and three at the bottom. haven't had in on the road yet. i imagine its going to be ruff as ..........
