Hi Guys,
I found a guy who has a bunch of new Selectro hubs loose in a box and I asked him if he had any for the M37 (part #11022-01 from what I've read). He didn't know the part numbers of what he had, so he's asking me for the physical info/measurements to see if he can ID them. I don't know jack about these hubs, so can you tell me what he should be looking for....I'm guessing spline count, axle diameter, number/diameter of mounting holes, etc??
I did find the MileMarker application chart on the web, but it lists 5 specs for the 11022 and no dash numbers. There's only one for 16 splines and the other specs for that are 6 bolt mounting and axle OD of 1.437. Any other help you can provide would be appreciated. Oh.....is the part number on the hub anywhere? If so can you tell me where he should look?
thanks,
Help with Selectro Hubs
Re: Help with Selectro Hubs
Bob,
Talk to Tom at Snake River 4 x 4, that is who I got my Selectros from. I seem to remember that he just got more in about a month or two ago.
- SSGT
I keep the hubs in stock, so I ran out to the shop and grabbed one, and the micrometer.
Outer flange is 4.670"
Hole centers across 4"
One hole to the next, center to center 2"
16 spline
outer shaft splines 1.400"
inner shaft splines 1.280 "
Sorry to say, I see no visable markings or number to distiguish it from any other hub.
16 spline
www.snakeriver4x4.com
G-7117 Chevy
G-7117 Chevy
Tom....WOW! Thanks for the info. I'll let you know what I find.
