gas tank vent fitting
jim0311
Post by jim0311 »
Anyone have a source for these fittings? I need one or at the least what size fits the threads on the gas tank?
Jim
xm708
Re: gas tank vent fitting
Post by xm708 »
I probably have one if it is the first vent piece on the tank ?
ed
jim0311
Post by jim0311 »
Ed how much would you want for the item?
Jim
xm708
Post by xm708 »
how about 10 for the part and 6 to ship usps ?
ed
jim0311
Post by jim0311 »
Ed thanks. i found one the other day.
jim
pwrwagonfire
Post by pwrwagonfire »
xm708 wrote:how about 10 for the part and 6 to ship usps ?
ed
Ed, could you post a picture of this for me? I may be interested....
I got a newly manufactured "fuel pick up" from VPW, and whilst it looks GREAT, and is very well made, it has no vent line connection :?
snowdad
Post by snowdad »
How does one make sure this item is working? Want to make sure it is in working order before I reassemble the tank.
Phillip
Brett
Post by Brett »
Phillip,
The vent is designed to allow air into the tank, but not out, during fording when the vent on the gas cap is closed. otherwise the fumes and fuel could be sucked into the intake. If its clean, I would check it with my mouth. you should be able to blow into the inverted flare fitting but it should close if you try to apply suction.
Brett
snowdad
Post by snowdad »
Thanks Brett. Think I got it. Will try this weekend.
