CARB SWAP
CARB SWAP
I am thinking of swapping out the carburetor on my "M". Yea I know BLASPHEMY!!! I am looking along the lines of serviceability and possibly performance. I did a swap on my Willys M38 using an adapter and a Rochester 2bbl. It was a slight improvement. I only did this as my original carb had a melt down (backfired and burned. Man was that an exciting few moments). The 2bbl route was cheaper at the time since I had the parts laying around. Replacing the oil bath filter is not a concern. I want to keep it simple. Any suggestions...John
Backfires and their associated carb fires do get your attention, don't they?
If it ever happens again, don't panic. Keep your foot off the gas, turn off the ignition and stomp on the starter. It will suck the fire down into the cylinders. If it becomes a recurring problem, you may have to reset your timing and/or check for burned valves.
Faster than a speeding snail
I was outside the vehicle adjusting the timing when she burped. The first thing I tried was what you suggested. Evidently I had a fuel line crack from working around it during a filter change. I managed to get my shirt off and smother it. It is amazing how quick things melt. Oh well I didn't have to shave my eyebrow for a while. God how I hate stack fires...John
- SSGT
Of course the first swap would be the civilian Carter Ball & Ball. I have heard of one other the bolts right up. Tom
www.snakeriver4x4.com
G-7117 Chevy
G-7117 Chevy
Carb overhaul
rixm37 wrote:Seaking of carbs. How much of a job is it to rebuild a stock carb for the M37 ? I've done a bunch of civilian carbs over the years. Is it really hard compared to like a Ford 2 barrel?
I did it this winter it is a bit more complex than old tractor carbs but not as complex as more modern auto carbs. Alan Bowes' carb overhaul instructions are very comprehensive. I did not mess with the governor. I will see how it runs first.
Paul f
- SSGT
I have carb kits here for $35.00 Tom @ Snake River
G-7117 Chevy
G-7117 Chevy
