v8 swop?
mikestotlar
v8 swop?
i just bought a 1952 m37, the motor needs rebuilt, im looking to put a v8 in to it!, the flat 6 thats in it has everything, not sure what to sell it for any ideas? plus im stuck on what motor i should put in to it. does any one know if they make a chevy bell house for the np420? or should i go a diffrent rout ?
powerwagontim
Re: v8 swop?
I put a Dodge 318 Poly into my Power Wagon, made a huge difference. I know a lot of folks have done the same with M37s. My suggestion is to keep it a Dodge engine, not a Chevy.
Tim
Tim
Re: v8 swop?
...sigh...
What is your intended USE for the truck?
What is your budget?
What mechanical capabilities do you have?
Lots of discussion on this over the years - any engine swap depends on what your ultimate plans are for the truck.
Many engines - from 353 Detroits, to Cummins 4B diesel variants, to the excellent Small-Block Chevrolet motor, to Ford & lead-anchor
Dodge motors have been installed in the M37.
LOTS of info as well in the forums... as well as info available on the Power Wagon forums -
See the comments on the other forums that begin to discuss what engine options are available, then disintegrate into a peeing match over
'Dodge is better than Ford is better than Chevrolet' - some powertrains swap in easier, and kudos to the people that love one brand over another.
The truck doesn't know what powerplant is under the hood -
Consider also that other systems - brakes/steering/cooling - will need to be brought up to snuff, regardless of the engine of choice. Note that the
NP200 transfer case & standard 5.83 diff gears don't like to be hurried down the road.
Various transmissions have been installed behind these as well...
Re: v8 swop?
And don't DARE put GM brakes on your Dodge, right?powerwagontim wrote:I put a Dodge 318 Poly into my Power Wagon, made a huge difference. I know a lot of folks have done the same with M37s. My suggestion is to keep it a Dodge engine, not a Chevy.
Tim
