passenger seat bottom dimensions
36x24
Post by 36x24 »
Sarge has no springs, cover, etc. for the battery box/passenger seat bottom area. am making a 3/4" plywood cover for same. springs for back of passenger seat present and after some rusty spring replacement work great. have repro canvas set that looks like a 5" foam piece will fill nicely inside but my dimensions are guesstimates at best and SWAGs otherwise. looks to be about 16" x 36". anyone mind putting a tape measure on your OEM one and telling me what you get? As always....Many Thanks.
snowdad
Re: passenger seat bottom dimensions
Post by snowdad »
I am in the same boat as you. I have the base box but no part of the seat. I will watch this thread for the measurements.
Phillip
ZGjethro
Post by ZGjethro »
I will get back to you guys, hopefully tomorrow
Glenn
Post by Glenn »
WeeBee Webbing should be able to supply the correctly cut foam for the seat. That's all it is, just heavy foam. They have the correct stuff.
ZGjethro
Post by ZGjethro »
My seat is 36 5/8" X 19 1/2 ". It is cut from a plywood with a pattern of holes in it. I cannot vouch for certain if it is original. There is also a small notch cut out of the back right corner.
N1VSM
Post by N1VSM »
I have some dimensions & pictures that can send via email. PM me your address if you are interested.
- Jim
Thanks for the offer, Jim. I'm interested (the passengers in my M37 are complaining about the plywood seat), but my attempts at sending you a PM seem to be stuck in my outbox.
majorhitt
Post by majorhitt »
I hope this helps, Across the front the seat plywood is 36 1/2 ' across the back it's 35" The side nearest the door has jog in it. This is where you have the 1 1/2" difference. The front to back is 19 3/4". Lets say you cut your seat bottom 19 3/4 by 36 1/2". The back left corner you have to cut out a small piece about 7" by 1 1/2 " I guess you really don't have to cut it out. The seat bottom I used had the canvas on it ,so my measurement ma be a little over. I was going to post a picture, however I can't it tells me my file is too big.
snowdad
Post by snowdad »
Majorhitt, you can use pixsizer to downsize to a smaller size then post it. I can send you the link that I keep on my desktop if you wish?
Phillip
N1VSM
Post by N1VSM »
While we're at it, is anyone interested in a set of springs for the seats? (Driver back & bottom, pass. back) Mine are up for grabs. PM for details.
majorhitt
Post by majorhitt »
I would appreciate the link. Thanks Ed
