M37 Exhaust Manifold
Does anyone know what the casting # is? My spare sold to me as NOS (who knows, it looks perfect) has # 620954-13 on the under side. I thought there was an old thread here about this somewhere but can"t find it. Thanks.
RICK
M 152 CDN
M 56 (V41)
M 152 CDN
M 56 (V41)
Re: M37 Exhaust Manifold
Additional info- Spare has typed part # taped on with cellophane tape. It says " 2805 00 040 1312 MANIFOLD 1 EA. A-4/75 SM"
Doesn't match my parts book # for "Manifold with w/heat control VALVE assy." Anybody recognize the part #?
RICK
M 152 CDN
M 56 (V41)
M 152 CDN
M 56 (V41)
Response for NSN 2805-00-040-1312
Item Name: MANIFOLD,EXHAUST
Maker: Chrysler
MRC Requirement Statement Clear Text Reply
NAME ITEM NAME MANIFOLD,EXHAUST
ACQW INLET CONNECTION TYPE FLANGED
ADFX CENTER TO CENTER DISTANCE ANY ACCEPTABLE
BETWEEN MOUNTING HOLES
ALONG WIDTH
ADFY CENTER TO CENTER DISTANCE 3.375 INCHES NOMINAL
ALONG LENGTH
ADUZ CENTER TO CENTER DISTANCE 7.438 INCHES NOMINAL
BETWEEN BOLT HOLES ALONG
LENGTH
AECS BOLT HOLE QUANTITY 2
AECS BOLT HOLE QUANTITY 4
AGNJ OPENING DIAMETER ANY ACCEPTABLE
AHNX BOLT HOLE DIAMETER 0.450 INCHES NOMINAL
AHNX BOLT HOLE DIAMETER 0.562 INCHES NOMINAL
AWZX OUTLET END CONNECTION TYPE FLANGED
AYJT OUTLET QUANTITY 1
BJTH INLET QUANTITY 6
BJTJ BOLT HOLE CIRCLE DIAMETER 2.562 INCHES NOMINAL
BJTK OUTLET CONNECTION BOLT HOLE 2
QUANTITY
BJTL OUTLET CONNECTION BOLT HOLE 0.465 INCHES NOMINAL
DIAMETER
BJTM OUTLET CONNECTION BOLT HOLE ANY ACCEPTABLE
CIRCLE DIAMETER
BJTR TEMP REGULATING VALVE INCLUDED
OPENING
FEAT SPECIAL FEATURES 2.450 IN. SQUARE TEMPERATURE
REGULATING VALVE OPENING WITH
BUTTERFLY VALVE DISK AND
WINTER-SUMMER ADJUSTMENT FEATURE
MATL MATERIAL IRON, CAST
Maker: Chrysler
ALONG WIDTH
ALONG LENGTH
LENGTH
QUANTITY
DIAMETER
CIRCLE DIAMETER
OPENING
The M37 parts manual TM 9-2320-212-34P dated April 1972 lists the folowing on page 23:
2805-040-1312 Manifold, Exhaust: with heat control valve assembly 7994017 (19207)
Illustration on page 35:
HTH, Carter
Webshots, Truck resto pix:
http://news.webshots.com/album/247061965WWtrqv
HTH, Carter
Wow that was quick. Thanks to you both!!! I just checked my 212-20P Feb 1960 and the # is the same there. I was looking in ORD 9 SNL G-741 January 1954 which doesn't list FSN #. I bought the spare years ago for short $ hoping the guy had it listed correctly. Always wondered if I was just storing a giant fishing weight.
RICK
M 152 CDN
M 56 (V41)
M 152 CDN
M 56 (V41)
