Fender heater innovation!
powerwagontim
Post by powerwagontim »
I was working on installing the fender heater today. I mounted the air distribution box and then was looking at the path from the defroster exit port to the dash, and it sure seemed like the cowl vent would interfere with the flex duct. I first thought that a 4" aluminum 90 degree elbow might make the turn easier, so I went and rummaged around in my dryer ducting bin. (I am a renovation contractor) Instead of the elbow, my eyes fell on a dryer fitting that will connect a dryer and allow it to be pushed right up to the wall while the vent stays in the wall. With some easy modifications, it fit right on top of the distribution box, aims righ toward the hole in the dash and easily clears the cowl vent and the turn signal flasher bolted to the side of the glove box.
The link is a picture of the type of fitting I so clumsily tried to describe.
http://www.repairclinic.com/PartDetail/ ... ee-Vent/71
Tim
m37jarhead
Re: Fender heater innovation!
Post by m37jarhead »
Great fix for distribution box to the defroster box hook up.... I'll use it.
Thanks for sharing this idea.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
powerwagontim
I have not made the final hookups on it yet, but it sure seems like it will work well. I would be interested to hear from folks with this setup and hear if the flex tube from the distribution box to the defroster duct interferes with the cowl vent. Maybe there are different distribution boxes that dont interfere, but mine sure would.
Tim
