T-case rant
T-case rant
Changing the fluid in the t-case yesterday. Don't you think that it would have been designed so that the lubricant is a FRU? Sure, draining is easy enough, but filling it was oh such a joy! I need to get a pump or something ... Anyone have a clever shade-tree work around?
Re: T-case rant
I use a tool made for that, it looks like a big syringe with a piece of clear tubing to go into the TC (or tranny, or differentials) They dont cost a lot and are a lot easier.
The Power Wagon master cylinder is the worst though. It is forward of the firewall, but still down at the frame level, with lots of stuff in between you and the fill plug. Really bad setup. I ended up making a new MC cover with 2 ports and plumbed a fill line and a vent line up to the firewall where I could reach it. Has a small reservoir out of a junked car to fill it with. Why didnt the Dodge engineers figure that one out?
Pick up one of those pumps and you will be a happy camper!
Tim
Tim
Re: T-case rant
I use a suction gun, new production ones like Tim described are available at most auto parts stores, the one pictured is WWII GI issue model.
Click on thumbnail for larger view.
http://news.webshots.com/album/559353479ogiJtR
Re: T-case rant
GOOD EVENING,
You can get a lower outboard lower unit oil change pump for a marine supply or on the computher. They screw on to most gear oil containers and it has a hose that you can put in the fill hose. works great for me. Good Luck, BOB
Re: T-case rant
I bought one of those plastic "syringe" it is so poorly made, the end you attach the hose to is tapered and smooth, as soon as I had gear lube in it, the hose fell off, the end had so much taper that even trying to clamp the hose on, as I tightened the clamp, the hose simply slid off.
Best advice if you purchase one, also purchase small cans of PVC glue and cleaner, glue the hose on first, once you introduce oil its to late.
Rich
Rich
Re: T-case rant
My gear oil is in a 5 gal bucket. I have a lid with a pump and a long hose. With the M37 it takes soldier 2 to pump the bucket and soldier 1 to hold the hose. But on my 5 tons, just soldier 1 is needed.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
- W_A_Watson_II
Re: T-case rant
My gear oil is in a 5 gal bucket. I have a lid with a pump and a long hose. However I do it with one Soldier, that is as long as the Soldier properly places the bucket where they can reach the pump handle.
Re: T-case rant
Ummm, what's a "FRU?"N1VSM wrote: Don't you think that it would have beef designed so that the lubricant is a FRU?
Re: T-case rant
Field Replaceable Unit. I know - a serious misuse of the term.Lifer wrote:Ummm, what's a "FRU?"N1VSM wrote: Don't you think that it would have beef designed so that the lubricant is a FRU?
(Gee, whiz. Did I really type "beef"? I must be hungry.)
Re: T-case rant
Great idea. Never seen something like this.8543bob wrote:GOOD EVENING,
- pwrwagonfire
- SSGT
Re: T-case rant
powerwagontim wrote:I use a tool made for that, it looks like a big syringe with a piece of clear tubing to go into the TC (or tranny, or differentials) They dont cost a lot and are a lot easier.
Tim
I agree...the MCs on the wm300s and such are a major PITA!
Re: T-case rant
I use a pump that I purchased at Auto Zone! it will fit on a gallon oil jug and comes with a hose and a fitting to hold it in place while your pumping which is really a clean one man job,it works great with all types a lubes and around $10.00 the pump will adapt to quart bottles also.
It's worth looking into.
hb
hb
