Charles, rightly so, points out that that his vehicles do not leak when they leave his shop, using all his experience and the products available today a leak free vehicle is quite possible and no doubt enjoyable to own. His vehicles aren't just for showroom display, they are everything from private vehicles to workhorses that will see regular on and off-road use so I don't blame him for being proud (and a whisker defensive) of what they achieve at M Series Rebuild. Other folks on here that restore vehicles also do a great job but may miss a worn seal surface and end up with a resulting weep but no tears are shed over it.
My point is, most folks do a good job at the level they have attained in experience and skill.
Restored and origonal have many meanings.....
Restored (returned to factory build quality and originality - a lot of folks achieve this)
Restored (Returned better than factory build quality and mostly origonal - fewer achieve this)
Restored a bit... (Returned to working order but a tidy unit, mostly origonal - Lots of these out there)
Restored (Returned to working order but not origonal, some new parts used - Many folks achieve this)
Restored (Returned to working order, modded and not origonal, tidy though... (this would be my truck
Restored ( They cleaned the rust off the bonnet, rest of truck looks like hell but hey, E-Bay, here we come - Rare and expensive, Bid now....)
Reestorred - ( Well, its gotta gun mount, hooks fer hangin up the roadkill, Tractur Tires and uh biga$$ engun for fogin thru thuh swampy stuff)
All origonal (not restored a real gem, minor rust, all origonal, well worth buying)
All origonal (Pity it was used in the last demolition derby)
All origonal (you can't quite make out the shape of the vehicle under all the blackberries etc. and you think there is some paint left)
All origonal (yes, all origonal and all there, just a pity it's been left to weather and you can barely make out the shape of the vehicle due to rust having eaten a good percentage of it)
NB - All vehicles classed as all origonal (except the one that is a real gem) should be on E-Bay real soon, also classed as rare, quite expensive and you really should bid now
Hope this clears some confusion up!!
Best Regards - MM
