Charles:
In a previous post (Brake System Question) you mention a vacuum booster ("The disc system and the original drum system is VASTLY improved by adding a booster to the system. The most economical way to do this is to simply install a vacuum booster; it's a relatively easy install and well worth the cost and effort to put it in place.").
Please provide some additional details on adding this to the original drum system (Booster type [NAPA number], how and where mounted, etc)
Hal
Brake question for Charles
