Jerry Can Strap
Jerry Can Strap
Ok guys, how is the strap supposed to be fastened to the gas can cradle? I got a new strap and it came as two pieces with one buckle. The longer of the two canvas straps has a plain end that looks as if it needs to be sewn or use anther buckle. The shorter strap already has a loop sewn in it? What am I missing? How do these attach to the slotted holes in the cradle :? ?
mike_l
Re: Jerry Can Strap
Post by mike_l »
I've always seen the older straps fastened with solid rivets (not the blind/pop rivets). I don't know how you are going to get the strap with the sewn loop on unless you cut open the loop.
Mike
Marion, IN
1954 M37 W/OW
1953 M101
Indiana MVPA
Lifer
Re: Jerry Can Strap
Post by Lifer »
The ones we had in Germany all had one long strap that fed down through the front, around the bottom, and up through the back slot. The two-piece straps can be riveted in place, as already mentioned, or sewn in place (if you know a lady who would be willing to do the job).
Re: Jerry Can Strap
Thanks guys, Rivets it will be. Picked up some at lunch. :)
I find as I am in the home stretch what should be the simplest task winds up the most aggravating :roll:
