screw Needed for E Brake
SierraM37
Post by SierraM37 »
Anyone know the size of the screw that threads through the three holes on the emergency brake band directly adjacent to the J Bolt? Want to know if I can fab something or procure locally with something similar and modify it.
Part number is NP-35775 according to figure 08-3 on page 212 of the exploded parts manual I have. It also appears to be double nutted on top. If I get that done, the transfer case is complete. Thanks in advance.
Todd
'52 M37 W/W
'52 M37 WOW
'01 Dodge Durango
'07 Jeep Rubicon (JK)
Re: screw Needed for E Brake
SierraM37 wrote:Anyone know the size of the screw that threads through the three holes on the emergency brake band directly adjacent to the J Bolt? Want to know if I can fab something or procure locally with something similar and modify it.
It is simply a 1/4" bolt, easy access where bolts are sold, you can either double nut after adjusting as you mentioned or use 1 self locking nut.
SierraM37
Thanks Charles
Post by SierraM37 »
Thanks Charles once again for the simple and effective advice. Cheers.
Todd
'52 M37 W/W
'52 M37 WOW
'01 Dodge Durango
