Anybody here use the pertronix module for your m37 ? If so did you like the results ?
ed
pertronix
I bought one from Charles and installed it several years ago and have been happy with the results, the engine starts easily and the unit produces a much stronger spark at the plugs than with the orig. points/condenser set-up. I plan to get one for the red truck when I'm further along with the project.
It is simply an act of replacing mechanical points with a magnetic sensor that still does the same job. Hotter spark can only come if you upgrade to a hotter coil. The hall effect sensor eliminates the need to sharpen an old skill called setting the points. If you prefer not to be bothered with mechanical point setting and frequent replacement then the Pertronix Hal effect sensor is the ticket for you. If you want more performance you will need to spend more money then just the cost of the Pertronix unit.
- CPL
This all reminds me of a fellow on my M series jeep web site forum. He posted this note:
Don't take me wrong. I think we do need to soak up some of the modernization thing. Just look here. Every minute we spend on this keyboard could have been spent driving or putzing with the big M!
Well how many guys here recall how often you adjusted your ignition points from 1950 through 1970? I seem to recall feeling the degredation in performance about 1500 miles and I was usually back under the hood adjusting them. I didn't mind it back then. It kept you on a regular under the hood visit schedule and you often found other things while you were there to sort out. I still don't mind crawling in there every 1000 or so miles.How are you guys dealing with the mechanical points in the distributor? I only got 5,000 miles out of mine and I had to adjust them. Thinking about that Pertronix thing.
I did it and was very satisfied.
I also matched it to a Pertronics coil. Much hotter spark.
I do have one little bit of advice if you are a bit OCD/ paranoid like me.
My truck lives in an area subject to frequent close lightning strikes
( fire lookout) .
I have lost ALL my electronics in everything a couple of times.
So I keep a set of points on a dist mounting plate in my glove box.
5 min swap if I need it!
J.B.
( fire lookout) .
J.B.
coil
That brings up a new question about coils. I have not seen any coils for the original style distributor except stock is there something out there taht is better than stock. I need a coil too but I will buy new production not NOS only because those coils are old just not used.
ed
ed
