Bracket on windshield frame
Lifer
Post by Lifer »
Yes, please! We can't see what you're trying to describe. A picture will help greatly! :)
ron hardin
Brackets on windshield frame
Post by ron hardin »
I hope these come throughImageevent.com/ronsm_37 refurb
cuz
Post by cuz »
Username does not exist
Please double check the URL and try again
Already Have an account?
Did your forget your username and/or password? Have it emailed to you
Need to Login? Log in now
Want to Join?
Do you want to join for free? Join Now
• Log In • About Us • Terms • Privacy • What's Ne
Link won't work without your username & password. You can only link photos that are not in private albums.
ron hardin
bracket
Thanks, but that is not the bracket. I'll try again on the pic. Me and computers just don't click
Ron
ron hardin
bracket
Bracket on drivers side. What is it for? (FINALLY- A PHOTO)
The same bracket on passenger side Edit
Add Comment (0 total)
Nikon E2100 Full EXIF / IPTC
Photo 1 of 2, DSCN0617.JPG, 58KB, 640x480, 0 Hits
Other Sizes: Medium Original
Properties | Link Back to Thumbnails
[ur
Just My 2 Cents, Again
It looks like one-of kind bracket, for a mirror, and the passenger side looks the same? :?
cuz
Post by cuz »
Or if the specialty brackets were on the truck the same time as that auto style mirror bolted to the door they may have been for the old dual whip CB antennas.
Master Yota
Post by Master Yota »
IMS the hole for an antenna should be about 3/4" in diameter. An antenna mount is a good idea. Might have also held a driving or auxiliary light.
Ray
1953 CDN. M37
1954 CDN. M152
Lifer
Post by Lifer »
Whatever it is, it sure ain't stock. Now, you can decide whether or not you want to keep it. Your truck - your choice. ;)
ron hardin
bracket
Thanks to all of you for your input.
The bracket on the other side is a duplicate of the one shown and is upside down compared to the one on the drivers side.
I don't think they were used for mirrors because the stock mirror mounts are still in place and I will be using them as the project progresses.
I had thought of antennae or aux lights, but there are not any holes that would indicate wires were hooked up.
I had more or less came to the same conclusion as Lifer, that they are not stock and I will be removing and welding the holes closed.
Thanks again
cuz
Post by cuz »
They don't extend far enough away from the body to allow the mounting of spotlights or large mirrors. CB antennas would have just ran their 3/16" diam. coax under the windshield or canvas top seal.
SOTVEN
Re: bracket
Post by SOTVEN »
ron hardin wrote:Thanks to all of you for your input.
Thanks again
I SAW AN M37 IN GREECE A WHILE AGO. IT HAD TWO MOUNTS LIKE THAT, AND A BENT PIPE (ABOUT AN INCH DIAMETER) RUNNING FROM THE ONE MOUNT, OVER THE TOP OF THE WINDSHIELD AND ENDING AT THE OTHER MOUNT, FOLLOWING THE SHAPE OF THE WINDSHIELD PREETY MUCH.. THE FLAT PIECE OF PIPE OVER THE WINDSHIELD FRAME WAS HOSTING 4 OFFROAD LIGHTS, AND THE WIRES WERE RUNNING FROM EACH LIGHT INTO SMALL HOLES ON THE PIPE AND DOWN TO THE MOUNT ON THE DRIVER'S SIDE, WHERE THEN THEY ENTERED THE CABIN THROUGH THE DOOR SLOT. NOT A FACTORY DESIGN, BUT QUITE SMART, SINCE IT ALLOWED ENOUGH CLEARANCE TO INSTALL AND REMOVE THE CABIN CANVAS WITHOUT REMOVING THE LIGHTS, PLUS ALL THE WIRES WERE PROTECTED FROM TREE BRANCHES. MAYBE YOUR TRUCK HAD AN OWNER WITH THIS SAME IDEA AT SOME POINT IN ITS PAST.
