Decided to take the truck to the gas station earlier today during the height of the storm. I planned to get gas then to run a few back roads to test out my defroster unit then come home. Didn't quite turn out that way. Halfway to the gas sation, I misjudged my speed going around a hairpin curve in the road, and plowed into a drift about 2 1/2 feet deep. I was STUCK...... I was going uphill and just slid as I tried to rock the truck back and forth. No luck. Got out, shoveled the snow from behind each tire, then tried backing out. Made slight progress, then stuck again. Kept this up for about 15 minutes, then tried to winch myself out using my hand come-along and tow strap. Come-along worked fine, but the tow strap is one of those kind that stretches a little, so I got nowhere. Only thing I did manage to do this way was to orient the ass end of the truck to where I could back downhill without getting into the drainage swail again. So, I tossed the strap and come-along into the back, and backed downhill until I could get a good enough running start to blow through the drift. Since I was better than halfway to the gas station, I decided to keep going. I questioned my decision the rest of the way to the gas station. Finally made it a half hour after leaving the house. The trip should have taken less than ten minutes even in this snow. Made the gas station and had a non-evenful return trip. But man..... what a learning experience.
First off, I now have lost faith in NDT's. As much as I like the look, I am not sure about them now. I got zero traction once I got stuck. 4 high and 4 low did nothing but spin the wheels. I'd dig around the wheels and still they spun. Chains would have helped but of course I don't have any. Even when moving the truck was squirrely all over the road. I skidded more than once. Yeah I got through, but thought I'd have better traction than I did. Granted the snow was over 6 inches deep most of the way(it was plowed once or twice). Maybe that had something to do with it.
One bright spot was my homemade defroster unit. The thing worked flawlessly. I used the low speed setting on my heater the whole time and the defroster kept the windshield ice, and fog free. The wipers were another story. Their performance was dismal at best. Fortunately the driver's side wiper worked the better of the two, and kep working. The passenger wiper would work, then bog down and quit, then work then quit, then it just quit and didn't work again until I got into my garage. I know I've been told , and now I realize for sure, they're junk. I'm actually sorry now that I bought them, but that's water under the bridge.
Hoping the other guys out there who decided to brave the storm made out better than I did. Overall it was fun, but next time I'm staying in next to the fireplace.
