Is the nut #7348982 that tightens against the lock holding the hub on suppossed to have a groove or is it worn?
rear hub nut ?
rear hub nut ?
Gerry
53 M37
53 M37
Re: rear hub nut ?
I'm assuming you are talking about the outer nut seal mating surface. No there should be no groove, it is common to see one though. You will need to replace it or the seal won't seal the oil from the hub bearings.Gerry wrote:Is the nut #7348982 that tightens against the lock holding the hub on suppossed to have a groove or is it worn?
