Site drops off line
Site drops off line
Has anyone else been getting a 404 failure page when using the forum? I emailed the web site manager at M37registry@g741.org several days ago and did not get any response.
- Site Admin
I haven't had that myself yet, keep me posted if it persists......
Regards - MM
Regards - MM
Trained Monkey on Guard
dodgem37@netspace.net.au
It's been happening off and on for about 5 days now. Usually late evening. Is your web site doing a lot of maintenance late evenings?
- Site Admin
The fault may be localised to a server somewhere in the net near you, I haven't had any problems yet and I think I may?? be the furthest member from the system anywhere, E-mail me if the problem continues past the middle of the week.....
Regards - MM
Regards - MM
- Site Admin
OK, I have contacted the host and I am awaiting an answer, hopefully the intermittent problem will be resolved soon....
Best Regards - MM
Best Regards - MM
- MSGT
Problems....
I have been getting error messages the last few days as well. Thought it was my computer for a while.......
- W_A_Watson_II
I've noticed issues relating to the links with in the board, those with and with out the "www" prefix. When the link dosn't work, adding the "www." in front fix's it.
Example:
viewtopic.php?p=18807#18807
http://www.g741.org/PHPBB/viewtopic.php?p=18807#18807
Example:
- W_A_Watson_II
