Another window question
Now I'm really confused. The parts list only calls out one part number for the window channel 7374789. Now on checking out the Tm 9-8030 fig 220 page 408 it shows what appears to be correct going by the installation instructions. What is in my door looks different because of the bracket that holds the limit stop. Yet if the drivers side was removed and installed in the passenger side it would look correct. So guy's is there a left and a right side window frame? If so I have two right sides.
I may be not clear in my description. The glass sits in a channel that has cut outs for the regulator pins. In the center bottom there is a bracket that has two bolts. The bolts hold the adjustable angle stop for window travel at the top of it's stroke. The glass holding channel is what has two different part numbers and I have two right side windows.m-37Bruce wrote:So we're talking the felted track/traveler on either end of the window? Does the panel continue to crank up, not stopping?
WINDOW FRAME
I DONT THINK YOU WANT TO START RE INVENTING SOMETHING THAT DODGE ENGINEERS WAS PAID BIG BUCKS TO MAKE, SIMPLE FIX GET THE RIGHT FRAME ( SIMPLE SOLUITION)
Re: WINDOW FRAME
Good point! Have you looked at the manuals remedy, I think I remember a mallet and a 2 X 4?GERALDO wrote:I DONT THINK YOU WANT TO START RE INVENTING SOMETHING THAT DODGE ENGINEERS WAS PAID BIG BUCKS TO MAKE, SIMPLE FIX GET THE RIGHT FRAME ( SIMPLE SOLUITION)
BTW, these parts/panels are all over, NOS, TO as well as REPRO.
