Extra plug on old M37 light switch
Anyone know what the extra smaller canon plug is on the old style light switch??? Thanks
1951 M37
1970 M35A2
1972 AM General M818
1988 Hagglunds BV206
2 M105A2 trailers
1970 M35A2
2 M105A2 trailers
The early Bendix-Scintilla light switch has an extra plug for the trailer harness which originally ran all the way from the switch's small plug to the rear trailer receptacle. This same switch was used on the M38 where it had the same harness setup. This switch was later superceded to a Bendix-Scintilla switch with only the unmachined boss where the small plug had been. As these two plug switches were attrited out the Army dropped the seperate trailer receptacle harnes and went to the molded rubber tap at the rear harness. These switches started phasing out in 1952.
Left is very early 10-34480 (G742 -7729684) Scintilla switch then center is 10-76555-1 (G742-7355600) Scintilla switch and right is first small single plug universal switch by Unicite # 160306 ( G749-7368702).
The G741 ORD 7 lists one more switch G742-7358637. I'm not sure which design this switch is.
And now we know the rest of the story!
Great explanation Wes, thanks for setting me straight, and educating us all!
Tim
Tim
Phil,
I like to believe it is. Both of the Scintilla switches are completely rebuildable and it's a shame that the subsequent switches were all deliberately built as throw aways. They will all interchange and you can even plug in and run the newest one in todays active duty MV's.
The early type switches would be worth more to someone wanting an orignal type switch in there early MV, they are clearly different in appearance, and can be harder to find now. However if you were to use the 1st design you would have to have a 2 piece rear harness for the veh. if you wanted any wires to the trailer socket.
68 M-715 MVPA# 2710
Actually you can use the early 2 plug type with a late harness. You simply do not use the small plug receptacle.
