PTO seal numbers... Anybody?
Anybody know some seal numbers for the PTO? Sliding shifter shaft seals,and output shaft seal. Also about those shifter shaft seals... Do they have the little coil tesion spring inside the seal?
- HingsingM37
I have down in notes a CR 7513 for the shifter seal. .750x1.375x.250" dual lip with garter spring.
CR#11209 for the PTO output shaft. 1.125x1.874x.250" , single lip with garter spring.You may want to double check these dims as I sold my PTO. I don't have it to look at
That's the same part numbers shown on the M37 cross ref parts list I downloaded from Cabel's site here last week.
