Are there amber 24V bulbs available for the front marker lights or am I better off changing the lenses to amber?
What are you guys running?
Front Marker Lights
Front Marker Lights
Did you just change to the goat lenses or the whole housing? If you changed the housing is there a provision for turn signals?Cal_Gary wrote:I run amber front lenses and gammagoat taillights.
My plan is to incorporate turn signals when I do the restoration.
I had to obtain entire housings on both ends because my truck was a basket case with no housings when I bought it. The goat housings have 3 single-phase bulbs so you will be able to run your service drive lights, to include turn signals but at the expense of the b/o marker and brake lights.
Lots of folks go this way in order to be seen at night.
- Site Admin
It's even easier to simply get an amber 24volt, 21 watt globe from a modern vehicle setup (most suppliers have them, I use 12 volt in my system though) and grind 1 bayonet pin off as they are offset, slip this in behind your clear lens and you have an amber light with the origonal "clear" look for your indicators.
I run them like this on my truck (front and rear) to keep the Australian transport requirements for lighting satisfied with my vehicle's setup. I run 4 marker sets on the rear, 2 red lens and 2 clear lens units, unusual maybe but it looks the part and I have the usual 2 on the front.
Regards - MM
Regards - MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Now that's the answer I was looking for. I wanted to keep the clear stock lens. Thanks MM
Now I'm on a mission to find two 24V Amber bulbs.
- Site Admin
I forgot to add, you can also simply use amber lens paint on clear bulbs, the reason I have mine setup with the amber bulb for the front indicator light is a 5 watt clear bulb in the second mount means I have my park light in there too and it is white per our regulations for the front of a vehicle.
Regards - MM
Regards - MM
paint
I tried the paint on (1) the bulb and (2) the lens, separately, that is. Wasn't happy with either. I finally decided to leave it white. In Taxachusetts, the only non-original part required is a light over the real license plate - well, and the plate itself.Monkey Man wrote:I forgot to add, you can also simply use amber lens paint on clear bulbs,
