Gauges
Gauges
Hi everyone,
A question regarding the Douglas connectors on the dash gauges. There are two connectors on the back, one is larger in diameter than the other, what one goes to the sender ? My wiring has been removed from the dash and I cannot find any detailed wiring info for the gauges in any of my manuals for the early series M37.
Greencom
Greencom
- Paul in Kempner, TX
- PFC
Wiring Diagram
TM 9-8030, 2 May 1955, page 258.
See the link below from Carl's site:
This shows the gauges. One of the gauge connectors is a male the other a female. If you look at the voltage gauge that only has one connector you can sort out what is what on the wiring diagram.
Hope this helps.
Hal
http://m37.crwdesigns.com/m37wiring.pdf
Hope this helps.
Hal
Hi Hal,
I've seen this diagram, I believe it's for the later B1 M37. My "53 does not have a turn signal or voltmeter. I'm not sure if the gauges have the same left/right connections but if they do it will help some. I cannot believe there are no complete wiring diagrams to be found for the early generation of M37's. There is a low resolution picture of the instrument panel in my TM-8030 manual but it's almost useless. Thanks for your time Hal
Greencom
Greencom
HI Tim,
Yeah I hope one turns up. It's strange that the government omitted it in the original manuals. The books cover every tiny repair detail but I guess nobody ever had to repair instrument panel electrics or replace damaged wiring. It's something that I've noticed only recently when I decided to rip out all of the Bubba wiring in the panel and do it right except there is no way to find out how. I like to do things by the book but there is no book.
There is a definite difference in the wiring from the first and second generation of M37's.
Greencom
Greencom
You could try emailing or calling Joe Hall of Vintage Wiring of Maine. He builds harnesses for these trucks and will probably be able to answer your question. He's a great guy too.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
S-89 Comm box
DJ,
I could not find any reference to what temp or oil gauge connectors go to the sender or the power. The wire numbers don't do me any good as I have no wires left, they've been removed. I'll just use mechanical gauges and be done with it. I guess the early fifties complete wiring diagram is a rarity.
Greencom
Greencom
Hey Greencom
Sorry the diagram did not help. I have a 52 and mine is the same as in the diagram. I have a volt meter and do not think I have seen an M37 without one. I have no turnsignal.
At any rate from the diagram you should be able to trace the power leads from the spider harness to the gauges you have. The other connection on the gauge goes to the sender.
I have a pic here somewhere of mine when I first opened it up and can e-mail it to you if you think it will help. Send me a PM and your e-mail address (52m37@charter.net).
I will take a look at mine this weekend and see if I can sort out if the larger connector is for the power or the sender.
Hal
'No battle plan survives first contact.'
Hal
52M37Hal,
Actually Hal I was wrong, I do have a voltmeter, I don't know what made me think I had a n ammeter. Anyway after some bench testing I determined what connectors go where at the temp and oil gauges. They are however quite out of calibration according to the data I have. I would like to take you up on your offer to e-mail me a picture on your panel. I will pm you. Thanks for your efforts.
Greencom
Greencom
