318 timing
What should the timing on my 318 be? Can’t seem to find a chart or any info
318 timing
bubba_got_you
- SGT
318 timing
May God grant me with the serenity to accept the things I cannot shoot, The ability to shoot the things I can and a place to hide the bodies
- W_A_Watson_II
Monkey Man
- Site Admin
I had problems setting up my timing due to a marked harmonic balancer making it impossible to read the notches, the simplest and most reliable method I have ever used is peaking the efficiency with a vacuum guage, simply slip it on where you have disconnected the vacuum advance from the distributor. I also cut a slot and made a cover in the rear cover on my firewall so I could loosen and tighten the distributor clamp without climbing over the engine with a custom bent spanner to get to the damn bolt...
There are some great articles on the net regarding peaking and tuning an engine with a vacuum guage, if you have multiple carburettors then I have found in my experience it is the best way to balance and check the tracking of these setups, a single Holley or Carter however is pretty simple to peak and it makes setting optimum timing a cinch.
Regards - MM
Regards - MM
Trained Monkey on Guard
dodgem37@netspace.net.au
- W_A_Watson_II
Lifer,
Yes, 35 Deg BTDC. I used my first Mopar Orange Box and Accell Super Coil back in 79/80 and was setting it at 8 Deg, and could not get the car to run. It would start but don't give it any throttle. After consulting the "Mopar Bible" in those days, I figured out I had to advance the timing to 35 Deg. Well, you couldn't get enough rotation out of the distributor with out the vacuum advance hitting the firewall, so I ended up moving the plu wires one hole,and once I hit the 35-40 Deg area she ran like a scalded ape.
On the M I used the Chrome Module and the instructions sate as below:
